22-02 error
   / 22-02 error #1
3Bladz
IL
a real 4320JD and a 3720JD 5610 Toolcat "Luigi"
Any ideas what to check for a 22-02 starter on error. The starter is not running as far as I can tell. The code clears when I shut it off and does not come back on right away. It has come on the last 4 times I ran it.
   / 22-02 error #2
The Electrical System SM for the "D" calls 22-02 a "Starter Relay Output Error". The flowchart for troubleshooting this is kinda long but the first thing I'd do is check the Starter Relay which is in one of the fuse blocks. The fuse block you are interested in has 12 fuses it looks like with four on the left and eight on the right. The relay of interest is the upper left one...right next to the ACC fuse. Looks like one of those plug-in jobs...make sure it is seated well.
   / 22-02 error
I have not had the code again yet. The machine has not been in a wet environment yet though and that is what bobcat thinks is causing it. I guess bobcat has seen problems with a sensor or something and they should have a solution soon.
2013 FORD F-450 UTILITY TRUCK (A51222)
2013 FORD F-450...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2013 FREIGHTLINER CASCADIA (A50854)
2013 FREIGHTLINER...
CHALLENGER VACUUM PUMPS (3) (A50854)
CHALLENGER VACUUM...
