2130 rear oil pump
/ 2130 rear oil pump #1
Bill Greenwood
I'm changing the rear oil pump in a 2130 John Deere I have removed all bolts connecting the tractor at join back of clutch houseing lifted shifter's off and removed diff top cover with 3p th arms including 2 bolts undershifters tractor still wont separate. Is there anything else that needs unhooked inside transmission or under the shifters to let it slide apart or is just a stuburn 30 year old gasket?
/ 2130 rear oil pump #2
I assume you disconnected the brake oil lines and the oil line to the pressure control valve, right side, under foot rest.
You did not miss the two bolts under the shifters. Did you remove the gear shift lever guide spring?
yes i did do the shifter rails need out too
/ 2130 rear oil pump #4
Then it should come apart.
How are you supporting the front and back?
2018 CATERPILLAR 326FL EXCAVATOR (A64279)
2018 CATERPILLAR...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A63688)
2023 Top Air ATV...
John Deere 5090GN (A60462)
John Deere 5090GN...
2025 Kubota L2502HST (A64119)
2025 Kubota...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A61572)
2025 HT360W Mini...
1999 GMC C7500 Dump Truck (A61573)
1999 GMC C7500...
