2120 WONT GO INTO ANY GEAR
   / 2120 WONT GO INTO ANY GEAR #1
Rancho Herevia
New Holland 2021
I changed the starter switch on my 2120, and not sure if I wired it wrong or just a coincidence that it won't go into any gear. Any ideas? Thanks
   / 2120 WONT GO INTO ANY GEAR #2
   / 2120 WONT GO INTO ANY GEAR #3
Which transmission does your 2120 have? The gear version or the HSS version?
Assuming that it is the HSS version:
If you mis-wired or left open the AC wire on the starter switch, then two of the fuses on the fuse box would not get power. One of these fuses feeds power to the HSS control module. It is the 10A fuse. I would check for power at the fuse box with the engine running and also check all the fuses. If the HSS control module does not have power then you can't go forward or reverse.
This is the one thing that I can think of that would be related to changing the starter switch. Everything else would be a coincidence and would be covered in the post above by @kirkawilson
UNUSED WOLVERINE TDB-11-72W 72" BUCKET (A57193)
UNUSED WOLVERINE...
2011 KUBOTA SVL90-2 SKID STEER (A52707)
2011 KUBOTA...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
2021 Polaris Electric Golf Cart (A56859)
2021 Polaris...
UNUSED FUTURE FT15 EXCAVATOR (A57192)
UNUSED FUTURE FT15...
1990 Ford F-450 Heil 10FT S/A Dump Truck (A55852)
1990 Ford F-450...
