2120 HSS command will not engage forward or reverse
   / 2120 HSS command will not engage forward or reverse #21
Here's a link to some of the Hitachi diode marking codes. Scroll down a little and the blue markings with dots are shown. Maybe that will help ID the specs on the diode and the part number. The diameter measurement should determine the final part, but it looks like its either U17E or V17E if the lines are blue and the dots are black). HITACHI(2) - MARKING CODE @wiki - アットウィキ
https://img.atwikiimg.com/www21.atwiki.jp/mcmaster/attach/349/710/U17E_01.jpg
https://img.atwikiimg.com/www21.atwiki.jp/mcmaster/attach/349/711/V17E_01.jpg
   / 2120 HSS command will not engage forward or reverse #22
   / 2120 HSS command will not engage forward or reverse #23
A very late update to this thread: The V19E that I mentioned in the post above is not correct and is too small.
I think that Ford850 is correct, the original diode is the Hitachi U17E.
The U17E is now obsolete and is quite difficult to obtain. There are places that sell it for ~$10 each but they have a 10 piece minimum order or more.
I had ordered the the U19E which is about $2 each with a 5 piece minimum and tried it in my controller and found that it works as well.
The diode is the first component in the path from the power lead. So if the diode goes bad, the controller loses power.
It seems that any general purpose diode that has specs similar to the Hitachi U17E or U19E would also serve as a good substitute.
Club Car Utility Cart (A55853)
Club Car Utility...
2015 Dodge Ram 1500 Pickup Truck (A55852)
2015 Dodge Ram...
1991 FREUHAUF 40FT BELLY DUMP TRAILER (A57880)
1991 FREUHAUF 40FT...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
