2120 Ford compact tractor occasionally goes into neutral
   / 2120 Ford compact tractor occasionally goes into neutral #1
90cummins
Veteran Member
Florida Ma.
Ford 1720 SSS 4x4 Turbo Charged
I知 doing a service on my friends 2120 HSS which has a couple operational issues.
Occasionally while operating the transmission will go into neutral then re-engage. Transmission is full and oil and filter have been changed.
It has done this for a couple years and does not act like an electrical issue.
Also the hydrostatic steering stops working at times then resumes.
These two systems are totally separate and do not act up at the same time.
Looking for advice.
90cummins
   / 2120 Ford compact tractor occasionally goes into neutral #2
FO-46 I&T shop manual says under troubleshooting paragraph 98:
1. Tractor will not move or operates erratically,
a. Engine clutch or transmission input shaft failure,
b. Transmission oil level low,
c. Charge pump or charge pressure relief valve defective,
d. Pump or motor cylinder block or valve plates defective,
e. Feed valve or neutral valve sticking open.
2009 Pierce 105ft. Quint Ladder T/A Fire Truck (A53422)
2009 Pierce 105ft...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A54811)
2010 Turfco...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
2012 BMW 328i Sedan (A53424)
2012 BMW 328i...
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
Hose Reel (A53424)
Hose Reel (A53424)
