2025R Mystery
   / 2025R Mystery #1
jdwebster
2025R
Posting because neither I nor JD can figure out what is going on with my tractor. I have a 2025R that is 3 years old with 75 hours on it (yes, not used much). The primary use is to spray my vineyard which is on a hillside with as much as 20+ degrees of slope, but not more than 25 degrees. I spray with a Rears 50 gallon pak blast that I fill to 35-40 gallons, and I have 5 75-lb weights on the front end to keep the front end down. Last season, I had an issue with water in my diesel. What happened was the tractor would lose power under significant load- if the sprayer tank was at 35 gallons and I tried to go uphill, I would lose power on the slope and the RPMs would plunge and if I didn’t let my foot off the drive, the engine would stall. Once I changed the fuel (to red diesel from a place that sells a lot of diesel) and the filters, the tractor ran fine… for a little while.
I’m now having what seems like the same issue. Replaced air, fuel filters, hydraulic fluid filter. Tractor went to JD and they replaced the injectors. No change. JD says hydraulic pressure and flow are ok. They are stumped and told me that until it breaks, they just dont know what to do. I can’t use a bigger tractor because my vineyard rows are 6 feet wide. We know that with this kind of load, the tractor is operating near the top of it’s operating range, but it worked fine before.
Looking for wisdom out there as to what I can check.
   / 2025R Mystery #2
Do see any change in color of exhaust when this problem occurs? I.e. Black smoke, gray smoke, etc.
If you let up some on the travel pedal does engine regain RPM?
Any change if you shut the sprayer pump off (presuming PTO)? Wondering if something in spray pump could be requiring a little more power at times.
   / 2025R Mystery
No change in color of exhaust that I’ve noticed. When I let up on the pedal, the engine does regain RPM, but then I’ve lost speed and to spray, I need a pretty constant speed. Letting up on the travel pedal is how I’ve been managing, but the machine just goes so slow…..
Turning the sprayer pump off (yes, PTO) does make a difference, but loss of power is still notable.
Thanks for your wisdom.
   / 2025R Mystery #4
At what gear range are you operating ??
   / 2025R Mystery
Mine only has low and high. So low 4WD
   / 2025R Mystery #6
How full is the fuel tank when the problem occurs? Wonder if there could be an issue with the pickup that shows up at those higher angles. Fuel, air, compression, you need all three, my guess is a fueling issue under heavy load... Next time you have the problem:
1. Check how much fuel is in the tank
2. Go back down to the bottom, and try reversing back up the hill. This could help determine if the operating angle has anything to do with it.
3. Go back to the bottom, and go up forward again and see if the problem happens at the exact same spot.
4. Go back to the bottom, fill the fuel tank all the way, and try again and see what happens.
You might try each step a few different times. If you can determine the problem can be replicated consistently, under the same conditions then you can start to eliminate potential causes.
   / 2025R Mystery
OK. Will try. I usually keep the tank at least 1/2 full. But the problem has occurred (going forward) with as low as 1/4 and as much as full.
   / 2025R Mystery
Interestingly, when JD sent out a repairman, the hydraulic pressure and flow tested low- which is why it went to the shop- but when they got it back to the shop, they said it tested great.
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2011 Ford Crown Victoria Sedan (A54815)
2011 Ford Crown...
LIMA MAC 60KW GENERATOR (A55745)
LIMA MAC 60KW...
17201 (A55852)
17201 (A55852)
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2018 Ford F-550 (A55973)
2018 Ford F-550...
