2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A55314)
Item Details
Auction ID
55314
Make
Brushwolf
Type
Ag Equip
Year
2022
Auction House
Fastline Auction, LLC
Model
ALPHA 165
North Carolina
Description: The Brush Wolf Alpha XP is a high-flow skid steer brush cutter with a 72-inch cutting width that can cut up to 10-inch diameter trees. It requires a hydraulic flow of 33-45 GPM and has a tip speed of 13,200-18,000 ft/min. Key specifications Cutting Width: 72 inches Hydraulic Flow Range: 3345 GPM Max Cutting Diameter: 10 inches Tip Speed: 13,20018,000 ft/min Overall Width: 75.25 inches Overall Length: 82 inches Weight: Approximately 2,320 lbs (3-blade) or 2,570 lbs (4-blade) Blades: Available with either a 3-blade or 4-blade carrier Features Direct Drive Hydraulic Motor: For efficient power transfer Open Front Design: V-notch design for increased operator precision when cutting trees and saplings Pressure Relief Valve: Protects the motor from pressure spikes Heavy-Duty Construction: Built for industrial and commercial applications Year: 2022 Make: Brushwolf Model: ALPHA-XP Serial No.: 41522 Stock No.: A0718 FASTLINE SALES REPRESENTATIVE(s) Bobby Kennerson bobby.kennerson@fastline.com 502-222-8303 Item Location - Address: Provided by Seller Item Location - City: Franklinville Item Location - State/Province: North Carolina Item Location - Postal/Zip Code: 27248 Item Location - Country: United States
This is a online bidding auction by Fastline Auction, LLC
see lot description, multiple locations, KY 40010
Starting Bid: 7500.00 USD
Auction Finishes: November 04, 2025 at 05:54 PM
Click Here To Bid Now!
Happy Bidding!
2007 DELTA TRAILER (A52472)
2007 DELTA TRAILER...
202479 (A54757)
202479 (A54757)
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A55973)
2014 MultiQuip...
Metal Bigfoot Lawn Art (A55853)
Metal Bigfoot Lawn...
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
