2019 JD 2032R
/ 2019 JD 2032R #1
gasman1075
Bronze Member
JD 2032R
I have a 2303R and am getting the ECU 1209.3 error code on the display It started right up I let in run for 20 minutes ( it was 12' F here this am ) it moved fine so I just parked it and plugged it in. I have a call into the dealer any thoughts ?
Thanks in advance
/ 2019 JD 2032R #2
If you get the JD TractorPlus app on your phone you can search fault codes.
/ 2019 JD 2032R
well I plugged it in and warmed it up and no more error code but thanks !
/ 2019 JD 2032R #5
On another forum I saw people with the same code. Some kind of exhaust sensor maybe. Seems lije it came up with cold temperatures.
/ 2019 JD 2032R
The dealer said fuel gelling can also be a culprit. Its plugged in and warm now so no code.
/ 2019 JD 2032R #7
This is interesting.. I have the JD app installed, and I have a 2019 2032R. So I searched for 1209.3. It returns "No Matching Results". So does this app only show results for codes that my (or your) particular tractor displayed?
It appears that you cannot search codes that show up on other (same model) tractors.
