2019/20 XR4150 Received an F11 code today
   / 2019/20 XR4150 Received an F11 code today #1
KP2654
LS XR4150
30 hours on tractor, and I was working the driveway today at ~2200 RPM when I noticed the engine speed starting to decrease. Saw the blinking red triangle and error code F11. Even with max throttle, max RPM's dropped to 1500. Limped to the shop with it thinking "Oh ****". As I was contemplating the next step, it occurred to me that maybe a reset would work. I popped the hood and was going to disconnect the negative battery cable when I discovered that it was very loose. Loose to the point that I was able to remove it without tools. I tightened the cable, restarted tractor, and all was good. Ran like a champ. Hopefully the loose cable was the issue and I didn't just kick the can down the road with the reset.
Just thought y'all might be interested in my experience.
   / 2019/20 XR4150 Received an F11 code today #2
Thank you for sharing.
I had an F11 code too, it was air in the fuel line when I ripped a gash in it.
Let us know if you have more issues. Always good to know these things! :thumbsup:
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
