2016 CK2610 Ignition
/ 2016 CK2610 Ignition #1
12Bravo
Eastern TN
Kioti CK2610 TLB, Gill 5' Scraper Blade (Tilt/Angle)
Hello All!
Was wondering if the CK2610 ignition could be bypassed and turned into a push start or something.
I find myself, yet again, with a stuck tractor. I've done the basic, battery check and connection checks, grounding checks. Everything leads to a faulty ignition switch. This is the second time I am having to replace this ignition and the third time having to deal with it.
What are my option? Am I stuck buy a new ignition or is there a work around for these tractors. From my understanding from someone on here, there isn't a computer on these. I don't know if that matters or not. Local dealership want's $125 a pop for this.
Thank you
/ 2016 CK2610 Ignition #2
Since your tractor is under 25 horsepower it probably does not have a computer. A wiring diagram would be good to have for this project. I used an automobile ignition switch from NAPA to replace the factory switch on my Mitsubishi D2350. That allowed me to turn on all the electrical power. I then added a bat handle high current toggle switch to operate the glow plugs. Good luck!!
/ 2016 CK2610 Ignition #3
I fixed my own just by spraying WD40 into it and rotating the key multiple times 2 yrs. ago and it hasn't let me down since.
/ 2016 CK2610 Ignition #4
Hello All!
Thank you
If you still have the old switches take them apart and clean the contacts. Now you have spares...
/ 2016 CK2610 Ignition #5
You could add a simple push button switch to use in combination with your existing switch as long as the switch still activates the fuel cutoff solenoid.
For temporary use these are quite handy;
They install between your battery power and the start command wire on your starter solenoid.
Thank you all for your replies.
Turns out I had a shorted wire under the dash, battery terminals needed cleaned, and new connectors were needed.
Thanks again everyone!
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Jayco Octane T32H Toy Hauler (A62613)
2019 Jayco Octane...
JLG Scissor Lift (A64047)
JLG Scissor Lift...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
2020 CAT FORKLIFT TL1255D (A63569)
2020 CAT FORKLIFT...
