2014 MASSIMO MSU-800 GEAR BOX/TRANSMISSION ISSUES
   / 2014 MASSIMO MSU-800 GEAR BOX/TRANSMISSION ISSUES #1
SKIDOG1974
WILLARD, MISSOURI
MASSIMO MSU-800
I have her tore apart and see that the shifter and linkage all work perfect. So I am thinking that the issue is inside the gear box or transmission. Here was the scenario, I was driving on normal terrain (road) about 40 mph. All of the sudden, I heard a loud noise and all the sudden I was not in gear. The shifter and indicator were still on "H" 2 wd. So I coasted to the nearest driveway and had to tow it with my trailer. Again, I tried to shift into all gears including reverse, and 4wd. The shifter and the indicator lights would change and the linkage would move properly but the side by side would not engage gears what so ever. What next?
Thank you for your time in this matter.
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A55314)
2023 Kubota...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
SPEEDAIRE COMPRESSOR (A55745)
SPEEDAIRE...
(INOP) 2016 AUTOCAR EXPEDITOR GARBAGE TRUCK (A54756)
(INOP) 2016...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
John Deere M665 Zero Turn Mower (A55851)
John Deere M665...
