2014 Intimidator 1000 diesel
   / 2014 Intimidator 1000 diesel #1
kwbretired
Horseshoe Bend, Arkansas
Case 485, John Deere 5425, & John Deere Skid Steer 333D
Was wondering if some one could lend some help to figure out why the electric radiator fon will not stop running. I had to unplug it to stop it. Is there a temperature sensor somewhere on the engine that possibly failed ????
Anyone have some ideas? Bump.
   / 2014 Intimidator 1000 diesel #3
I would guess temp sensor or fan relay switch :2cents:
   / 2014 Intimidator 1000 diesel #4
Normally the temp switch would be on the radiator.
I called myself looking for an unplugged wire & or a sensor but didn't see anything. I'll be back in Arkansas next week & I'll check again. I am thinking its a wire that has pulled loose just have not found it yet. I rode through a wooded area & most likely a stick knocked something off. Thanks for your responses. If something else comes to mind let me know. Thanks again.
Made it back to Arkansas last week. I looked all over for a loose / broke wire but didn't see anything. Never found the heat sensor. I plugged the fan motor back in & it stayed off??????? Guess it fixed itself. Hopefully I won't have this issue again. But i wouldn't be surprised if the problem comes back.
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
24635 (A55853)
24635 (A55853)
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2025 Swict 72in Bucket Skid Steer Attachment (A55851)
2025 Swict 72in...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
