200hr oil warning
   / 200hr oil warning #1
tomhalligan
Cub Cadet GT 3200
How do I clear the warning flashing on my hour guage? I have changed the oil and filter and double checked the oil level.
I've tried disconnecting the battery terminal, but the warning is still flashing upon starting up...?
   / 200hr oil warning #2
The following is from the operators manual.
"The LCD will alternately flash the recorded hours and CHG and OIL for five minutes after every 50 hrs of recorded operation. The maintenance interval lasts for two hours(from 50-52, 100-102, 150-152, etc). The LCD will flash as described above for five minutes every time the tractor engine has been started during the maintenance interval."
   / 200hr oil warning
Thank you for your input, I did notice that the warning went out shortly after starting to cut the grass, I supposed that it must have had something to do with the function of the timer rather than the condition of the oil system... Thank's for the clarification.
Tom
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
2010 Ford Fusion Passenger Car (A51694)
2010 Ford Fusion...
378740 (A51572)
378740 (A51572)
2021 QUALITY CARGO, LLC QUALITY CARGO, LLC (A52472)
2021 QUALITY...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
