200CX question
   / 200CX question #1
Phunge
I was at the dealer and playing with a 200cx loader on a 2320. I noticed while raising the loader (stick all the way back) that if I tried to curl the bucket at the same time (stick to the back and right) the loader would stop raising. It would not raise and curl at the same time.
Is this expected behaviour? Seems very limiting.
   / 200CX question #2
Ithink I remember someone asking this a while back - and the answer was it was typical
brian
   / 200CX question #3
I just went out to the barn and tried it because I hadn't noticed before. My bucket slows down quite a bit, maybe about 50% but still lifts and curls at the same time. Possibly due to limited hydraulic flow? Possibly if the bucket was loaded to capacity it would stop. I'll try tomorrow when moving rocks.
   / 200CX question #4
What RPM was the tractor running at?
   / 200CX question #5
I believe it would depend on the tractor it is mounted on. It would be better on a 2520 than it would on a 2305.
   / 200CX question
Hmmm -- Maybe I just didn't have enough RPMs
   / 200CX question #7
Well I tried it when the bucket was full to overflowing with dirt and could not get the bucket to curl while the loader was lifting unless I was at 2800 (or more) RPM. Guess you were right about the rpms. I never noticed that before.:rolleyes:
   / 200CX question
Thanks Ed.
2006 Case 570MXT Turbo Tractor Loader with Box Blade (A55787)
2006 Case 570MXT...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
2013 Ford F-150 4X4 Pickup Truck (A55788)
2013 Ford F-150...
2022 Polaris Ranger Utility Cart (A55788)
2022 Polaris...
NEW 24ft Feed Bunk Wagon (A55301)
NEW 24ft Feed Bunk...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
