netwayne
Bronze Member
We have a 2305 and got this FEL back in Sept and have attached and detached it a number of times with not too much difficulty. Today, we went to attach it after it had been sitting for maybe 2 months. It was way low and therefore way out of alignment. Figured the hydraulics bled down which lowered the profile on the FEL sitting on the ground. We decided to pull the tractor up perpendicular to the FEL just to get the hoses attached to see if we could raise it back to it's proper height. Not sure if this would work but we were going to try it. Trouble was we were unable to make two of the hydraulic connections to the tractor. It was the black and blue connections which raise and lower the FEL. We tried starting the tractor and moving the joystick to relieve pressure on the tractor side but to no avail. I see from another thread in here that you can press the tips on the hose ends to relieve pressure too? Gonna try that now. Was curious if anyone else has run into this issue of the FEL settling and also difficulty making the hose connections. Any suggestions would be greatly appreciated. Thanks TBNers!!
