200CX hose routing
   / 200CX hose routing #1
techwrtr2
Platinum Member
Alabama PA
Which one?
I'm contemplating a machine change, possibly to a 2x20 tractor w/200CX loader. Something that worries me about them is where the hoses from the loader hook up to the tractor. Every tractor I've seen either in person or in pictures has a long loop of hoses dangling almost to the ground. My usage isn't all on perfect terrain and I have a hard time believing those hoses never will get caught and possibly ripped away.
Am I totally baseless in my concern? What have folk done to avoid this kind of problem?
   / 200CX hose routing #2
The hoses have plenty of slack for hookup (at least on my 2320), but there is a wire hook under the floor board to hold the hoses up. After I install the loader, I put the hoses in the hook and then pull the slack up above the loader arms. It works fine and I've never had a problem.
   / 200CX hose routing #3
The hoses do hang down low on the 2520/2720 tractors.
I use a bungee cord to hold the hoses up on my 2720.
   / 200CX hose routing #4
I see you have the ROPS-mounted forward work lights. Did you install them yourself? I'm curious if they use an existing wiring harness on the tractor such that you just bolt them on and plug them in?
   / 200CX hose routing #5
The lights were installed by my dealer.
From what I understand, the lights plug into the existing wiring harness that is behind the seat.
   / 200CX hose routing #6
Do the ROPS-mounted forward lights come on automatically with the front grill lights or are they independantly controllable?
   / 200CX hose routing #7
Yes the lights work off of the headlight switch.
   / 200CX hose routing #8
Thanks! I'm thinking about mail ordering a set of lights and installing them myself. My 2720 was supposed to be delivered this week but there was a last minute snafu with the dealer on filling the rear tires and now it's delayed a few days. Boo Hiss.
   / 200CX hose routing #9
Not to be sarcastic, but the hoses should only be about 3 inches Max below the floor board, at least that is all the lower on my 2520. As stated by another user, there is a hook that they rest in.
   / 200CX hose routing #10
Someone else will need to confirm this, but I believe my hoses hang slightly lower than 3". I am being sarcastic.
2000 GROVE RT640E MOBILE CRANE (A51406)
2000 GROVE RT640E...
Ford F550 Dump Truck (A47384)
Ford F550 Dump...
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A54313)
2016 WESTERN STAR...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
