2009 T300 Filters
/ 2009 T300 Filters #1
les.houston
2009 TYM T300 w/ Mitsubishi S4L engine.
Not sure this will help anyone, but here is what I have so far for non-TYM filter part #'s: (Dealer confirmed that use of Non-TYM filters would not void the TYM 5 Year Warranty...I have the email for legal backup...)
Oil: WIX 51365 or NAPA Gold FIL 1365 (about $8)
Outer Air: WIX 46438, or NAPA FIL 6438 (about $42)
Primary Air: WIX 42985 or NAPA FIL 2985 (about $27)
Fuel: Could not find a WIX, NAPA, Donaldson, Puralotor, or FRAM cross reference.
Mitsubishi 31A6200317 (Filter)
Mitsubishi 31A6200318 (Large O Ring)
Mitsubishi 31A6200319 (Small O Ring)
(The O rings do not come with the Filter, I would suggest ordering these when replacing the filter...prevents leaks...trust me...found out the hard way)
/ 2009 T300 Filters #2
Also with with Mobil Oil Filter: M1-108
/ 2009 T300 Filters #3
From what I have herd that's correct. The only thing is to make sure to use a good quality brand filter. If your engine fails under warranty and the filter is the cause of the problem the filter company is the one who has to cover the repair job not the tractor or engine manufacturer. So avoid any no name or store house brand filters when under warranty. If you don't use the OEM filter get a Baldwin, NAPA, Wix, Fleetguard, Donaldson or other high quality filter.
