2007 Cub Cadet RZT 42 PTO Clutch Fell Off!?!?
   / 2007 Cub Cadet RZT 42 PTO Clutch Fell Off!?!? #1
bjackson
Ohio
Cub Cadet RZT 42
I am very confused and looking for some help. I have a 2007 Cub Cadet RZT 42 with less than 200 hours on it. It has been well cared for since new. The electric PTO clutch came off the other day while I was mowing. The bolt's threads were messed up so I purchased a new bolt and it threaded in just fine and seated properly. I turned the mower back on and the blades were moving just a bit (without the PTO on) and the mower had a loud vibration to it and the bolt is coming loose again. Do I need a new PTO clutch?
Thank you for any input.
   / 2007 Cub Cadet RZT 42 PTO Clutch Fell Off!?!? #2
Take the clutch back off and check the bearings in the clutch. there should be a top and bottom bearing. Turn the bearings feeling for any roughness. if anything doesn't feel right then replace the clutch. Also while you have it off. Start the mower and see if the crankshaft has a wobble in it or not. Most likely not, unless you hit something, but if it does, then you are looking at major expensive repairs.
   / 2007 Cub Cadet RZT 42 PTO Clutch Fell Off!?!? #3
You are not the first to wonder why yours came off so easy, and there are times when we actually have quite a time getting them off. We have seen the bolts come out within a few hours from purchase which makes you wonder of the effort to put one on right! Doesn't seem to make much difference as to the make from what we have seen.
Get a parts break down and make sure you have all the pieces and use lock tite to put it back together.
I removed the bottom pulley and the pressure plate. Can't seem to get the top of the PTO housing or pressure plate off. Any suggestions?
X-CEL GOOSENECK TRAILER (A54756)
X-CEL GOOSENECK...
2014 Aerway Aerator (A55973)
2014 Aerway...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
Sakai SV540T Padfoot Compact Roller (A57453)
Sakai SV540T...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2017 Peterbilt 348 Hood 7000 Grapple Truck (A55973)
2017 Peterbilt 348...
