2006 F-250 diesel cab heating problem
   / 2006 F-250 diesel cab heating problem #11
Robert_in_NY said:
I want to update this thread, the fluid was low and was the problem. Never had that situation before but it was a very cheap and easy fix.
Glad I could help.
Like David said, keep an eye on the fluid level. Hopefully it was just one of those life events that cannot be explained, and not the beginning of a major problem.
Glad I could help.
That is what I am hoping for, I have never owned a vehicle that used radiator fluid so I am crossing my fingers this is just a freak occurance.
   / 2006 F-250 diesel cab heating problem #13
The radiator overflow tank where you "add fluid" will not typically allow the heater not to work as you originally discribed. However, if the radiator is low it will do what you discribed. Since adding fluid to the radiator overflow tank "fixed" the immediate problem, you were happy. However if the fluid in the overflow tank was not below the level that would allow air into the radiator, then the radiator is getting air from somewhere, which would then prevent it from sucking fluid in from the overflow tank which it does on a syphone type of system. As long as the radiator and coolant system is sealed, it works great but if a leak or hole in the system ever allows air in, it prevents the radiator from pulling in fluid when it cools down, and instead pulls air in from the hole/leak. If the hole is really small, as the radiator heats up, it will expand the fluid and push the excess into the overflow tank, but as it cools, it won't bring it back, thereby causing the radiator itself to become low on fluid, even though the tank still has fluid in it. If the hole is more of an ooze, than a leak then it might bring part of the fluid back for a while till the amount of air in the system builds up.
My thoughts would be to run a pressure check on the system using a coolant system pressure testor. Do it cold and hot for best results. I can loan you mine if you want to drop by and borrow it. Heck, I will even preform the test for you, no charge. Transportation costs might offset the savings, so do so at your own risk.
7710 is still sitting, work changed, cars needed to be purchased, so I am concentrating on doing a bill paydown so that I am not at the mercy of people when they want to change my work schedule. Since I now have a truck to move it with provided I can remove the duals, it is getting closer. I continue to use the JD2555 regularly.
David from jax
Thanks David, glad to hear you have a plan down there. I know things will work out for you, your a good person and good things happen to good people. Getting those bills paid down will be a big step. I have been able to keep most of my bills in check but since my injury I fell behind but this year I paid everything off (well, till I bought two new tractors for the farm). So I know its a good feeling when you finally get them paid off :thumbsup:
The overflow tank was empty, it took about a gallon though to fill it up (maybe just over as I had a partial gallon I started with and had to open another gallon but didn't use it all). I am keeping an eye on it and if it keeps dropping I will have it tested if I can't find any visible leaks.
2013 International Bucket Truck (A55973)
2013 International...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2013 Ford F-150...
2011 SOUTHWEST  GOOSENECK (A58214)
2011 SOUTHWEST...
Bobcat T590 (A53317)
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
