2006 Cub Cadet LT1550 died
   / 2006 Cub Cadet LT1550 died #1
bobbyj
Cub Cadet LT 1500 Series
I want to spread some manure this morning and the Cub Cadet would not start. I had not used it in a while and it was chilly, so I jumped it with one of those portable jumpers. She fired right up. I hooked up the newer spreader and headed out to the pile. I set the brake and let it run while I filled up the spreader.
Then she just died. No electric, nothing. Battery reads 12.6 volts and there's plenty of gas. Turn the key and nothing lights up, no hour meter, no LEDs, nada.
I checked the seat safety switch and it's OPEN and still no electricals.
Any ideas? Thanks.
Bobby
   / 2006 Cub Cadet LT1550 died #2
Clean all major cable ends grounds included!
   / 2006 Cub Cadet LT1550 died #3
I would check to see if you have a fusable link in it somewhere. Google the model number and wiring diagram and see. There maybe a fuse somewhere too. :thumbsup:
I found it. It was a 20 Amp Fuse buried behind the engine and wires. What a bugger to get to. Runs great again!
Thanks!
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
2017 CATERPILLAR M316F MOBILE EXCAVATOR (A52707)
2017 CATERPILLAR...
Kubota RTV X900 (A53317)
Kubota RTV X900...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
