2005 Bombardier 400 4x4 starter
   / 2005 Bombardier 400 4x4 starter #1
Toby873
Bronze Member
myakka city, Florida
Branson 4720i
starter is really squealing, blowing fuses, so I know its going. appears to be a two bolt install, anything tricky I need to know before I replace it myself?
   / 2005 Bombardier 400 4x4 starter #2
Too late, but here goes.
Usually easy job, like you said 2 bolts.
Just make sure you get a good ground between the starter body, bolts and engine as that is the ground for the starter. So sand the area where the bolt head tightens on the starter and the area between the starter and engine where the bolt goes through. Your just trying to make sure you have a good ground.
Then on the positive side, make sure the cable is clean on the end and in good shape so you get all 12 volts going to your new starter.
Good time to check the ground cable from the battery to the engine as well. If you have a lazy starter, always check for dirty grounds. They are often the problem.
If everything is making good contact your new starter will wind over great.
thanks spud, will do, still cranking but new starter is on the shelf standing by
26ft x 42ft Double Garage All Metal Building (New/Unused) (A59225)
26ft x 42ft Double...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2025 JMR 66in Single Cylinder Brush Grapple Skid Steer Attachment (A56857)
2025 JMR 66in...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2000 Cummins DGDB 100kW Standby Diesel Generator (A56857)
2000 Cummins DGDB...
2023 Kubota U55-5R1 Mini Excavator (A56435)
2023 Kubota...
