2004 6000 4WD Hub Oil
/ 2004 6000 4WD Hub Oil #1
501oldman
6000 DI 4WD
Newbie here. What is the correct hub oil for the front wheel hub. Need to replace the O ring, but cannot find the oil type in my manual. Thanks!
Thanks. That was the only oil I could see relating to the front axle/differential, but wanted to make sure.
/ 2004 6000 4WD Hub Oil #4
agree, GL5 80/90, or 75/90 hypoid gear oil will do fine. some use a heaver 85/140 but i steer clear. Kubota tractors come factory supplied sometimes with hydraulic fluid, but too thin in my estimation. don't overfill as may compromise seals, etc, you know that. welcome to forum, regards
