2002 John Deere 4410 with Implements
   / 2002 John Deere 4410 with Implements #1
briteslid
I have a 2002 JD 4410, turfs, 4x4, e-hydro, rear & mid PTO and 3rd SCV, 348 hrs, with JD 430 loader, JD 72" MMM, and Woods RB72 (72" rear blade). Also have 2005 JD X-495, with 54" MMM, 3bag powerflow, 47" snowblower, and JD 48" plug aerator. Both tractors are great but due to the Delphi Packard Electric bankruptcy looks like my wife will unemployed, I am selling the 2002 JD 4410 with all three implements for $19,000 it is in excellent shape pictures can be seen on the gallery. With my 4 acres and our pond redone and other dirt moving the JD X-495 fits my situation better for mowing and blowing snow, also I have a very soft yard in the Spring and late Fall so the X is all around better.
I'm located in Newton Falls, Ohio 44444 (Northeastern Ohio)
if interested call Brian at (330) 872-3398.
Also the 2005 JD 48" plug aerator to pull behind a garden tractor is for sale also used it once in late April, and really don't need it due to my situation now it cost $400 new and will sell for $250.
As for the X-495, I love it quite a downstep from the JD 4410
but is much more adapt for mowing around the close spots that you would push mow, cut that down by 70% and the 3 bag powerflow bagger does a great job. Only things I don't like on the X-495 that the 4410 has are on 4410 you control the glow plug time instead of like on the X-495 when you turn the key on if you don't turn it to start immediately will heat glow plugs for 7 seconds and the X is a little more cold blooded don't even need to heat up the 4410 till about 45 degrees out. Also the X-495 fuel guage is not to reliable stays on full then drops to 1/2 tank just check it often, have heard the irregular tank shape is the problem. Also wish I could bypass the RIO switch on the X-495 when backing up mowing, after using the 4410 and just backing up it's a change.
Thanks, for your time
2017 Dodge Charger Sedan (A59231)
2017 Dodge Charger...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
