2000BD 4wd not working
   / 2000BD 4wd not working #1
scesnick
Veteran Member
Garrett County Md. ( Western Md.)
Kubota MX5100
I was plowing up a field yesterday for a food plot and i was working the tractor pretty good when I heard a sort of clanking noise in the front of the tractor and now my 4wd does not work. I had this apart last year and I think ( keyword is think ) I know what happened but do you guys have any thoughts on what broke?
I will not have a chance to tear it down until this weekend.
   / 2000BD 4wd not working #2
If we are playing guessing games, I guess your balls fell out.
   / 2000BD 4wd not working #4
Scesnick,
I can't answer for Norm but I'm pretty sure he is referring to the driveshaft ball bearings that fit fore and aft on the drive line. There are 6 (balls) per end and spring loaded...and occasionally they do indeed pop out and leave the drive shaft laying in your tube. It would be the first area to look before tearing into the FWD.
Mark
   / 2000BD 4wd not working #5
mark777 said:
Scesnick,
Mark
That's my guess.
Mark777,
Hey thanks, I never thought of that. That could very well be what is wrong. You would think if it was a bearing on one side the other side ( wheel) would start pulling. Am I correct in thinking that?
Rhinox Mechanical 40 mm Coupler (A52384)
Rhinox Mechanical...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2013 Toro Workman HDX Scissor Lift Utility Cart (A51691)
2013 Toro Workman...
CFG Industrial SAII100 (A50123)
CFG Industrial...
City of Buckhannon Onan 200 Set Stand By Generator (A52384)
City of Buckhannon...
2018 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 130...
