2000 tachometer
/ 2000 tachometer #1
kennyl123
Bronze Member
Pollock, LA
Ford 2000
Hey guys, I have a 1972 ford 2000 and I bought a new generator with tach drive. Hooked up and tach meter don't work. I replace the instrument cluster and cable and It still doesn't work. I took the cable off the drive and put old cable back on, nothing happened. Took cable drive off generator and hooked cable up and turned the gear with a screwdriver and cable moves. Re-installed all and still doe not work. It appears to me that the cable does not stick out far enough to engage gear when cable is tightened up to its stopping ring on the meter side. What can I do?
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
2013 John Deere 7200R Tractor (A66285)
2013 John Deere...
New 20'x20' All Steel Carport (A62679)
New 20'x20' All...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
Woods Brushbull BB60 3-Pt Rotary Mower (A66285)
Woods Brushbull...
