20 hp Kohler engine won't start hot
   / 20 hp Kohler engine won't start hot #1
CFHartman
Keyser WV
John Deer 2210
I have been looking over this site for an hour now trying to find out how to contact someone about starting a new forum. on trouble shooting small engines. We have a 20 hp Kohler engine at a cemetery I help mow. When it get's hot it won't start till it cools back down . If we had a small engine forum I could maybe get an answer to what is wrong.
   / 20 hp Kohler engine won't start hot #2
Sounds like a classic example of a bad coil.
   / 20 hp Kohler engine won't start hot #4
this is vote #3 for the coil
   / 20 hp Kohler engine won't start hot #5
This is a long-shot. What model mower do you have? I had the same problem with my Grasshopper. It turned out not to be a problem with the engine but with a loose ground wire on the frame. Try shaking the mower while you turn the key with the engine hot, if it starts you may have a loose wire. Good Luck.
   / 20 hp Kohler engine won't start hot #6
Vote number 4, for a bad coil.
   / 20 hp Kohler engine won't start hot #7
If the engine runs fine until you shut it off, then it is not the coil. Does the engine ever shut down when running at full throttle? Check spark, check gas line for vapor lock. Can you get it started by putting some gas in the carb?
   / 20 hp Kohler engine won't start hot #9
I agree it could be a faulty coil but, it could be that grass and debris is causing it to overheat and vapor lock, I would clean up the flywheel area and cylinder fins to see if it cures the issue.
   / 20 hp Kohler engine won't start hot #10
I give another vote for bad coil. I have a 14hp and that was the exact problem I had. Ran great until I shut it off and then would have to let it cool off before it would start. Changed coil and no more problem.
2012 Audi Q5 SUV (A42744)
2012 Audi Q5 SUV...
2013 ALLMAND LIGHT TOWER (A45046)
2013 ALLMAND LIGHT...
2012 KENWORTH T800 MID-ROOF SLEEPER (A45333)
2012 KENWORTH T800...
Western 8' Ultra Mount Plow (A42021)
Western 8' Ultra...
QA 72" Rock Grapple Bucket (A44502)
QA 72" Rock...
2015 BIG TEX 12’ SINGLE AXLE UTILITY TRAILER (A45046)
2015 BIG TEX 12’...
