20% grade
   / 20% grade #1
Ridew
Iselin, nj
None
My wife and I purchased a small farm that has a lot of grades. Most fields have less than 15% grade but some of the lower fields have 20% grade. The farm was plowed by a horse and plow. I am looking for suggestions on what type of tractor would be the best to buy in order to plow safely.
Any suggestions would be greatly appreciated
   / 20% grade #2
:welcome:
Just about any "normal" farm tractor should be fine. To feel comfortable, you may have to extend the track (width between the tires) to the widest setting. If you've ever paid attention to the tractors mowing the highway right-of-way, you may have noticed that the tires are set way apart. That's what determines the stability on a slope. Typical ROW slopes are cut to a 3:1 (33% slope). Also, filling (or ballasting) the tires will help a little.
   / 20% grade #6
Plow that kind of slope and I don't see how you avoid extreme erosion:thumbdown:
You sure you need to plow it??
   / 20% grade #7
fill the rear tires up with a liquid to add more ballast weight. and get that extra weight closer to the ground. can help reduce COG (center of gravity) for a tractor.
going SLOW, with plowing, ya going to be in and out of the furrow made from last pass of a plow. and if you hit the furrow wrong ya going to be tipping over. the faster you go, less chance you might be able to steer to keep things going. along with faster you go more likely hitting a bump on high side or going into a hole low side and suddenly tipping over.
many tractors, you can either swap rear wheels (one side for other side) to keep tread in correct direction. and gain a inch or 2. (it is all in the rims) and were things bolt up to the hubs. to get a wider stance.
some tractors ya have to buy spacers. to get a wider stance for the wheels.
they do sale "tilt meters" that mount on tractor. to help "give you an idea" of what angle you are at. it is by no means lets ya drive tractor right up to max degrees before tractor rolls over. but helps give you a better idea of things.
having ROPS (roll over protection system) is always good. (of course wear seat belt when ROPS is up)
do not be confused with FOPS or sunshades. they will not give you any protection in a roll over.
and of everything, do things in your own limits. if ya do not feel safe. then stop.
and with texasjohn, has stated do you really need to put in a field at that steep of an angle? it might be better area for a pasture for live stock. than actually growing a crop. erosion can be a killer.
   / 20% grade #9
Been there, short visits. 20% is the outer limit of the tiltmeter I have, and my pucker factor goes sooner than that. I've had my tractor on 3 wheels numerous times...not pleasant...so I been on slopes...am here to tell you that at those kind of angles any small hole/bump you hit throwing you in the wrong direction can be a rollover. I fear that regular plowing/planting/harvesting on such a slope not only gives extreme erosion, but will end up, sooner rather than later, in an unfortunate event.
OP seems to be new to farming and going immediately into a dicey situation..... Hope all works out for him. Land is already purchased but I advise avoiding the extreme slopes since they cannot be plowed up/down but across, at least until experience is gained. There is a whole lot to learn about how the center of gravity moves around a result of FEL weight/height, vehicle velocity, angle of front wheels, implement being pulled and how it is attached to tractor, weight in tires/on wheels/on front/on rear, etc. It happens so fast and there is very little the vehicle operator can do to stop a roll over once it is in progress.
If there is a TBN member who has numerous years experience of safely and successfully plowing and harvesting 20+ degree slopes, I'm hoping they will post information about the implements, tractor and practices they use to do it.
   / 20% grade #10
he could always purchase another horse team
1270 (A50490)
1270 (A50490)
2020 CASE CX37C EXCAVATOR (A51242)
2020 CASE CX37C...
2015 Chevrolet Tahoe SUV (A50324)
2015 Chevrolet...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2022 FREIGHTLINER M2 24FT BOX TRUCK (A51222)
2022 FREIGHTLINER...
2017 Wacker Neuson ST31 Compact Track Loader Skid Steer (A49461)
2017 Wacker Neuson...
