2 stroke starting problem
   / 2 stroke starting problem #1
mwatsonxx
I have a stihl chainsaw that has become difficult to start. The pull cord used to have a smooth action, but now it has become very jerky and almost impossible to pull. It will start and run eventually so its not seized.
Any ideas, thanks
   / 2 stroke starting problem #2
What model, does it have a decomp. valve, has it been thoroughly cleaned lately? I'd start by giving the clutch and recoil area a good cleaning. Pull the muffler off and see if there is any scoring on the piston or cylinder.
Andy
Thanks Andy,
The saw is now running smooth as silk and the jerkiness is back to normal, ie just a firm resistance.
I cleaned the spark plug and air filter. Then I discovered a very fine metal mesh filter on the exhaust outlet. It was 90% clogged up with black soot, cleaned it all off and - vroom vroom.
   / 2 stroke starting problem #4
Spark arrestor plugged. Got to run it a little harder to keep it clean or pull it out and burn it off with a torch. Make sure your mix is right too.
Andy
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2008 Ford Ambulance (A47477)
2008 Ford...
2020 Isuzu NPR Heil 8RLDB 8CuYd Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
RoGator RG1100C (A55302)
RoGator RG1100C...
