2-Spool Valve; series or parallel
   / 2-Spool Valve; series or parallel #1
Jay4200
Veteran Member
Hudson/Weare, NH
L4200GST w/ LA680 & BX2200D w/ LA211
I just picked up a valve for my remote project - it is a Sauer Danfoss 1627 (2-Spool, 10GPM w/ PB). It is specified as a "parallel circuit" (vs. series). What does that mean?
Edit: Never mind - I learned what I needed to know. It's all good.
JayC
   / 2-Spool Valve; series or parallel #2
Think of it in a way of christmas light strands. A bulb burns out in a series type, you then have a open circuit. No lights on any. (Of course some use a shunting type device that will keep them lit) If you had two bulbs sharing a 120 volt circuit, they would be each using 60 volts through each other in series. One burns out they both go dark.
Parallel will be like your circuit lets say in your living room. The current flows in any direction that is hooked up to the circuit. Your house type lamp at 120 volts uses 120 volts even if you had more hooked to the circuit because they do not feed through each other. If one burns out the others stay lit.
The hydraulics will flow much the same.
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A52705)
2012 VOLVO A40F...
2017 International DuraStar 4300 26FT Box Truck (A51692)
2017 International...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
2017 Ford Transit Connect Cargo Van (A51692)
2017 Ford Transit...
2013 Mitsubishi Fuso FEC72W 18ft Dovetail Flatbed Truck (A51692)
2013 Mitsubishi...
