Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,296
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
More projects. A few months ago I put a receiver hitch on the blade of my KX41 mini excavator.
The other day a contractor doing fuels reduction at my treefarm saw it and wanted one for his 11,000 lb machine. Moving his chipper around is always time-consuming, because he must always have a 4wd pickup nearby, and there needs to be room to maneuver the combo. Then the pickup is nearby, and liable to get hit by logs, or something. Moving the chipper to wherever the brush pile with the excavator that feeds it, is far more efficient. So we talked about it a little bit then built it out there in the woods. I had a 12" Harbor Freight receiver tube "in-stock (earmarked for a different project). Cut it in half, and the rest was all just "steel".
Welded with wire feed (miller MultiMatic200) .030 wire, running on an 8,000w generator (Duromax XP10000E).
Receiver stows behind the blade.
Tested it horsing a 6,000lb chipper around and decided it needed some blocks to firm it up (on each side of the receiver). Excavator can really torque on a hitch because the tracks can rotate in opposite directions, and backing the 6,000lb chipper over logs etc was a lot of force on the removable receiver. Also drilled another hole farther back to minimize the length of the pintle hitch.
All good now, it's solid as a rock.
