2" receiver tube on draw bar
   / 2" receiver tube on draw bar #1
imabass
Bronze Member
Pawnee, OK
JD 3020 Propane
I needed a couple extra inches on my hitch to accommodate my drag style brush hog. Instead of cutting down the pto shaft I decided to lengthen the draw bar. On the longest position, it was just inches too short. I came up with welding a receiver tube to the draw bar. This now accepts all my standard ball mounts that I have and will provide the extra few inches that I need. This may not be the ideal solution for dragging a heavy plow but that is not really in my things to do with this old tractor. This is just a 2.5x2.5 tube with 3/16 wall. I welded some 1' x 3/16 straps over the tube for additional support.
   / 2" receiver tube on draw bar #3
That's cool.
The draw bar on my tractor was missing when I bought it. I plan to make a draw bar with a 48" piece of receiver hitch.
I'm mostly going to pull a chain harrow and hopefully a pull type bush hog.
2019 Ram 5500 Dump Bed, VIN # 3C7WRNFL2KG599631 (A51572)
2019 Ram 5500 Dump...
Ground Works Fertilizer Spreader (A51573)
Ground Works...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
UNUSED CFG INDUSTRIAL EXCAVATOR ATTACHMENT SET (A51248)
UNUSED CFG...
