2 Questions
   / 2 Questions #1
jay_ch28
Connecticut
New Holland TC40D
How many hooks should be on the bucket? I've got a 72" bucket. Where the hydraulic cylinders mount up is pretty thick. So I was going to go with two there, but then people have told me that you should have three.
How what is a good size box blade for a TC40D? 60"? 72"?
Smaller will cut through the hard stuff better right?
Thanks in advance
Jay
   / 2 Questions #2
I have three hooks on my HD bucket without additional reinforement (center and ends). I use them mostly to pick up limbs and pull fence posts with a chain.
Whatever rear implement you use in the rear, it's best if you cover your tire tracks. Therefore, minimum 72" is the best way to go for non-angling implements like a box blade and minimum 84" for angling implements like scraper blade or york rake.
Mark
   / 2 Questions #3
I run 4 3/8" hooks on the upper edge of my 72" bucket. I like 4 because I can make 2 independent chain loops to pick up almost anything. The upper lip of the bucket was filled in with a strip of metal for reinforcement before welding on the hooks.
I run a 96" box blade on my Ford/ NH 2120 which is only somewhat larger than your TC40. I've used it for over 10 years and I like the width.
Andy
   / 2 Questions #4
you might mention in this thread that your loader is an M246 Bush Hog so some folks don't think you have a 16LA. On my 16LA loader I made use of some empty pin holes on the loader and it's been all the hooks I've needed.
16LA Loader Hooks
As far as boxblades, I think I would go for the 72". I had a 60 for my Ford Jubilee and another one that's 66" with no scarifiers. I think I could pull a 72" blade with no problem.
2 1/2 Ton Military Truck, 6x6, 16' Flatbed (A52384)
2 1/2 Ton Military...
23311 (A51694)
23311 (A51694)
Pallet Fees (A50775)
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53473)
Michelin CARGOXBIB...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
CFG Industrial SAII100 (A50123)
CFG Industrial...
