2 pt to 3 pt tiller hitch conversion
   / 2 pt to 3 pt tiller hitch conversion #1
fjberres
D.C. area
Kubota BX2350
I bought a used P1205s Mitsubishi tiller with a 2 pt hitch. I need to convert it to a 3 pt hitch. There were some postings of this modification with pics, but I did not note the posters names and I cannot find the keywords to locate them. Any help with this would be appreciated!
   / 2 pt to 3 pt tiller hitch conversion #2
I'm guessing that you have a 23 hp tractor so it shouldn't be too bad to convert with adding lug to what you have already. When I did mine for a 35 hp Cat one I had to cut off all the existing bracket down to the bare tube and build back with 1/2" plate, it was expensive. Watch out for the length and angle at various lift heights of PTO shaft with slip clutch as that will tell you how long to extend the brackets. Hope you got cutting torch and welder and drill for 3/4" & 7/8" holes, that's for cat one, I don't know what size holes for Cat 0. bjr
   / 2 pt to 3 pt tiller hitch conversion #3
I did this conversion for a Yanmar 1201a. Not familiar with your model, but if you search under my name- you will be able to find the post about it.
2015 JLG 2632ES 26FT Electric Scissor Lift (A50322)
2015 JLG 2632ES...
John Deere Z930M (A50121)
John Deere Z930M...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50322)
2013 Vermeer V800...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
