2 lever hydraulic loader problem
/ 2 lever hydraulic loader problem #1
Brucifer
San Antonio, TX
Ford 1700
I have a Ford 1700 with front loader. It is old and needs help but still shreds the weeds very well. Today I fired it up to do some shredding and went to move the bucket. The levers both worked in only one direction hydraulicly. Lift up and dump. In the other direction no joy:mad:. Checked fluid it was a little low so I add about 2 quarts. Looked good on dip stick so I leaned on the lever to lower the bucket and blew a hose.
Does my control valve have something that can be stuck and not move even thought the lever moved? Don't remember the brand of valve I replaced it a few years ago, but it worked up until now.
Thanks for the help, But no QDs. All hard pipe and hose. I was hoping for someone to tell me there is a froze check valve.
/ 2 lever hydraulic loader problem #4
Tractordata.com lists the 1700's hydraulics as "live" - I'm wondering if that's another term for "open center", as most non-monster tractors use - either way, I'm not at all familiar with that model but I wonder if you're onto something. A lot of loader valves use load checks, and if it sat for a while I would think those might be stuck.
If you have a manual for it, that may help you to know more... Steve
I replaced the bad hose and it's mate. The control valve had 2 removable covers. Under each is a spring designed to keep valve centered. Seemed to work as expected. Started tractor and worked fine. Like simple stuff. Thanks BuketCase. Yes I think it is a open center valve.
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
Kenworth T6 (A63688)
(2) Firestone 282-26 Tires w/Rims (A64127)
(2) Firestone...
1994 New Holland 580 Square Baler (A63688)
1994 New Holland...
2016 Ford Fusion S Sedan (A59231)
2016 Ford Fusion S...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
