Oil & Fuel 2[emoji641][emoji641][emoji641] Filter protection/relocation advice
   / 2 Filter protection/relocation advice #1
Sarge338
Bronze Member
Mahindra 2555
Good afternoon, folks.
I have a 2555 that developed a fuel leak yesterday after clearing some, apparently, 3000 year old muscadine grape vines. The leak appears to be coming from the water sensor on the bottom of the filter. This is now the second time a filter has been damaged by something popping up from under the tractor to hit it. The first was my hydraulic filter.
Does anyone have any recommendations for protecting or moving these filters? I thought about putting some plates under them, but the only solid place to mount the plates would be to the frame, and I’m not sure about drilling/tapping the frame or welding to it. So, I’m thinking moving them may be the best option, but I was wondering if anyone else had done it, and if so, where did you move them to?
Thanks!
   / 2 Filter protection/relocation advice #2
I replaced my oem filter with a higher capacity and lower micron filter a few years ago, relocating it in the process. I put mine on using existing threaded holes in the loader frame. It's up and out of the way enough, but it would have been easy to add an "L" shaped plate underneath the filter and between the filter and loader frame.
Simple enough idea (the L bracket), and yet I didn’t even think about. Thank you!
2020 John Deere R4023 Sprayer (A53342)
2020 John Deere...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
20ft Shipping Container (A51573)
20ft Shipping...
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
JOHN DEERE 1700 (A53084)
JOHN DEERE 1700...
Hustler Zero Turn Mower (A51573)
Hustler Zero Turn...
