1st Tractor
   / 1st Tractor #1
Passaconaway
NH
Kubota 7610
I'm thinking about buying a new Kubota B7610HSD($13970) with a LA352 loader and a B2660 front snow blower($2500). I've got a 1200 foot northern NH gravel driveway to clear and maintain. I'd use the tractor to get firewood off my 10 acres and landscape also. Would this be a reasonable setup for me at the price ? Is the 60 inch dealer recommended snow blower too big for this machine ? Thanks.
   / 1st Tractor #2
Sounds like a good set up for what you're going to use it for. The 7610 will easily handle a 60" blower. I'm not positive on the pricing for your area-- but it seems to be in line.
Good luck /forums/images/graemlins/smile.gif
Jeff
   / 1st Tractor #3
You'll love the tractor and it will work well for the needs you describe. You should probably consider a good boxblade as well. You can use it both as ballast for your loader work as well as to keep that long gravel driveway shaped up.
   / 1st Tractor #4
Passaconaway, I'd use the $2,500. to buy an older 4x4 plow truck. Unless you have all the time in the world 1200 feet is a lot of snow blowing.
David
   / 1st Tractor
hey tim whats a boxblade? /forums/images/graemlins/confused.gif
   / 1st Tractor #6
That is very good advise /forums/images/graemlins/grin.gif 1200 ft is a lot, not sure what he will find for $2500
   / 1st Tractor #7
I use a 60" snowblower on a NH TC24D, while the tractor is different, the horsepower is the same as the B7610. You will find the 60" blower to be a good fit for the tractor.
As for the question about the box blade, a basic design is a large heavy blade that is built like a 4 sided box, open on the bottom and the top. The blade is located at the rear. The front has scarifier teeth that are typically depth adjustable and removable, typically 4 to 6 teeth. They break up soil in advance of the blade. The two sides of the box hold the dirt inside and in front of the rear blade. This makes for a device that can be used to smooth and level the ground. If you have a gravel type driveway that washboards or ruts then using a box blade can help you relevel the driveway, fill in the ruts, etc.
For a 24hp tractor, a 48" box blade is a good match in size.
2023 CATERPILLAR 259D3 SKID STEER (A52705)
2023 CATERPILLAR...
2015 MACK CXU613 (A53843)
2015 MACK CXU613...
2016 KOMATSU D65PX-18 BULL DOZER (A53843)
2016 KOMATSU...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
TOFT 680 HYDRAULIC BREAKER FOR MID SIZED EXCAVATOR (A53843)
TOFT 680 HYDRAULIC...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
