1st time tractor owner here.
   / 1st time tractor owner here. #1
vincewine
waynesboro,georgia
yanmar 2000
I have a used yanmar 2000 25 hp 2wd tractor.
questions are.
What gear(h or L) and number gear should i be in when mowing with 4 ft. mower and what pto gear?
What gear when harrowing with 4ft.disk harrow?
Done busted 2 different radiator hoses so i'am doing something wrong.don't remember what gears i was in when i busted the hoses. Thanks.
   / 1st time tractor owner here. #2
Vince - Welcome to the club !
PTO 1st Gear - 540
Reguarding the gear you need to drive your tractor in depends on the ground condition, wet dry slick - Tall grass, short grass, thick grass, thin grass - Hills, flat etc etc - Just use the same logic you would if you were on a riding lawnmower - Too slow is better than too fast - Obviously safety is job #1.
Same ideas/concepts apply to harrowing. Probably a better question than what speed you should be at is "What RPM speed should I be at?" And I would say you need to be in the 2200 RPM range.
Hope this helps - I'm sure others will chime in.
Good Luck !
   / 1st time tractor owner here. #3
brusting rad. hoses shouldn't have anything to do with what gear you'er in. Probably just old radiator hoses that needed replacing any way
   / 1st time tractor owner here. #4
Welcome to TBN!!
My question too would be "why are the rad hoses breaking?" Is it simply that they are old and need replacing--If that is the case, you should replace all the rubber elements, hoses and belts.
Or is it because you are developing woo much pressure in the rad. Cap wrong, combustion leaks, over heating.
Again welcome!
Mike
Thanks guys. hoses looked new too me before they busted they ARE new now.thought about flushing the rad.before i ran it again.
   / 1st time tractor owner here. #6
When you get it all back together again check some things before you put it back to work. I would first test the idiot light for temp by grounding out the sensor wire to make sure the light comes on. 2) I would leave the cap off and look for air bubbles in the radiator (combustion leak--head gasket, crack) and I would examine the rad cap carefully (what is the pressure rating, can you compress the spring, is the rubber in good condition.
Flushing the system would definitely be a plus, especially if there is a lot of rusty or nasty looking junk. I believe that the 2000 does not have a water pump (one can be added, but does not come with one from the factory, if I remember correctly. The system depends on being clean for good circulation and cooling.
Mike
   / 1st time tractor owner here. #7
Mike
The YM2000 does have a water pump, 13lb cap.
Danny
   / 1st time tractor owner here. #8
Thanks Danny for correcting me. I could not remember which--must be the 1500 and 1700 huh? :eek:
Well then I have heard of the possibility of the water pump also drawing air and making bubbles, but most likely if you have bubbles it is combustion air.
Mike
Had'nt had a chance to flush the rad.yet.ran it today with the rad cap off no bubbles.
ran it for a while with the cap on and saw fluid coming out from the cap.Guess time to replace it ?
   / 1st time tractor owner here. #10
ran it for a while with the cap on and saw fluid coming out from the cap.Guess time to replace it?
The cap is designed to let water out as it warms and expands. The water should flow from the cap into the overflow bottle & then, as the engine cools back down, the water is sucked back into the engine. If the engine was warming up then it sounds like the water you saw should be normal.
Aaron
Parts@HoyeTractor.com
(940)592-0181
2002 Genie S-125 4x4 125ft Telescopic Boom Lift (A52377)
2002 Genie S-125...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51694)
iDrive TDS-2010H...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2012 Tiger 130BBL Vacuum Trailer (A53117)
2012 Tiger 130BBL...
UNUSED Clear Multi-wall Polycarbonate Pane (A53117)
UNUSED Clear...
