Oil & Fuel 1st Servicing on M8540
   / 1st Servicing on M8540 #1
MAK122061
Getting ready for the 50 hours service on new M8540. This is the 1st front wheel assit tractor I have owned. I've read the manual that came with the tractor. Not a lot of help. Any suggestions on changing the front differential, the front axle oil and the transmission fluid.
   / 1st Servicing on M8540 #2
Be prepared for a LOT of fluid !
When I did mine, I made a mess.
E/S
   / 1st Servicing on M8540 #3
   / 1st Servicing on M8540 #4
The front axle takes less oil than the manual describes. It lists a "front differential" and a "front axle" oil case. Actually, they are both just one reservoir.
Just fill the oil to the check hole or dipstick (depending on what you have), let it settle, then check it again. Most people in warm areas use gear oil rather than trans fluid.
Drain the front axle/differential oil from the two plugs on the bottom of the knuckles by each wheel. Some folks jack up the front and rock the front axle to make sure it all drains out. It doesn't have to be done again until 600 hours so might as well be thorough.
Be sure to save the round magnets that are inside the hydraulic filters. Most new filters don't come with them. Just wipe them off and re-install on the new filters.
"Lots of hydraulic fluid" is 15 gallons. I use a large washtub and then dip out the oil into 5 gallon containers with an old kitchen pot for recycling.
Engine oil is 3 gallons so the standard round oil change pan is not big enough. Can't remember if there are two drain plugs, one on each side of the propeller shaft. Too many tractors or too few brain cells to recall.
Thanks for all of the good information, I talked to the dealer I pruchased tractor from. Come to find out the labor is free on the 50 hour service and he told me I could come and learn how things are done. To good to pass up.
   / 1st Servicing on M8540 #6
Now thats a deal !
E/S
   / 1st Servicing on M8540 #7
Sure can't beat that.:thumbsup:
2023 John Deere 6110M Utility Tractor (A50657)
2023 John Deere...
2019 Allmand Light tower (A49461)
2019 Allmand Light...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
2013 Audi Q7 AWD SUV (A48082)
2013 Audi Q7 AWD...
2022 Club Car...
