1st Service
   / 1st Service #1
mitchdb
Fayette County, Texas
John Deere 4710
I have a 4710 with about 50 hours on it! What all does the 1st service consist of? It is just changing the motor oil and cleaning the filter?
Thanks!
   / 1st Service #2
What does your manual say to do?
   / 1st Service
Well, that's another issue! I put it in a safe place but I don't remember where that safe place was!
   / 1st Service #4
You can probably access your manual online at Deere's website. /forums/images/graemlins/smile.gif
I'd certainly suggest that you download the whole thing to a CD before Deere upgrades the 4x10's to something else and eliminates your manual online. Do the same thing with the online manuals for your loader, backhoe and whatever else before they become unavailable.
Good luck with your service. I just did my 200 hour a bit early just because it was spring and I thought it'd make more sense to do it early than late. /forums/images/graemlins/cool.gif
   / 1st Service #6
I must be riding in the slow boat. Every time I try to print the manual to a file I get gook. How do I download the manuals? Thanks. /forums/images/graemlins/confused.gif
   / 1st Service #7
Hi, Bender. I managed to save several sections of my manual but was not able to save the entire manual as a single file. Perhaps someone else has some advice.
What I did was was click
"File"
"Save as"
Then select the location/folder on my computer where I want to save it
Then under "Save as file type" select "Web archive, single file [*.mht]"
You will need to do this for each section you want to save to your computer. I am using I.E. 6. Hope this helps
   / 1st Service
The answer to my question:
Break-in - After First 50 Hours
· Change engine oil and filter.
· Change transmission oil and filter.
· Clean transmission suction screen.
· Change suction side filter.
· Check alternator belt tension.
· Check radiator hoses and clamps.
· Check air filter intake hoses and clamps.
· Check wheel bolt torque.
· Check tire air pressure.
· Check for loose, missing, or damaged parts.
· Lubricate lower brake pivot tubes.
· MFWD Models: Check front axle oil level.
· Check air restriction indicator. Replace only primary filter unless secondary filter is visibly damaged or indicator shows an air restriction after the primary filter has been changed.
2010 Cadillac CTS Performance Sedan (A48082)
2010 Cadillac CTS...
2010 Cadillac SRX Luxury SUV (A48082)
2010 Cadillac SRX...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
2011 Honda Pilot EX SUV (A50860)
2011 Honda Pilot...
2020 Chevrolet Malibu LT Sedan (A50860)
2020 Chevrolet...
2014 KALMAR 4X2 YARD DOG (A50854)
2014 KALMAR 4X2...
