1st Regen Mode and then to the Shop
   / 1st Regen Mode and then to the Shop #1
TractorGunn
Rogersville, MO
LS MT242HE, John Deere X300, Husqvarna MZT61
Hit the first regen mode on the tractor, seemed like it ran about 30 minutes or so, and she has about 28 hours on her now.
And the starter is at it again.
Funny thing is last time it did it after attaching the brush mower, this time it did it taking it off to put on the boxblade.
She's definitely going to the shop to figure this out.
Welp, they picked up my tractor this morning.
She wouldn't turn over either, guy tapped the starter while I turned the key, and she fired right up.
Sounds like it's going to be a couple weeks before I get her back.
   / 1st Regen Mode and then to the Shop #3
I sure am glad I have pre emissions tractors. When I read about the woes you all have on here, I thank myself I kept my somewhat vintage units. I had started to contemplate about upgrading to new tractors last year but didn't and I'm quietly thankfull I never did. Sometimes procrastination isn't all bad.
Bad enough owning emissions compliant cars that I cannot work on except for oil and oil fiter changes.
At least the automakers seem to have a handle on reliable emissions componets. tractor manufacturers don't in my view. To make it even worse, no tractor manufacturer's diagnostic tools (code readers and such) can be plugged into a different manufacturers tractors. For example, the Kubota scan tool cannot access triuble codes or components failures on say a Mahindra tractor, heck, you cannot even plug into the Mahindra diagnostic port because every manfacturer uses a unique gateway that no others can physically plug into. No standardization what so ever, quite unlike the OBD port on cars and trucks where you can access most everything emissions and drivetrain related with just about any scan tool.... and it also appears that the quality and longevity of emissions related components on newer tractors is lacking as well. My Autel scan tool plugs into our GM as well as our Ford and reads the computers seamlessly. I cannot even plug the Autel into a late model Kubota because the diagnostic port is unique to Kubota only.
I think it's all pure unadulterated hog wash and why I'm glad I kept my 2 pre 4 tractors. No emissions related garbage to fail and no unique code reader to read trouble codes which a dealer will charge you for.
When tractor builders first got into the 4-5 emissions standards they should have all sat down and standardized their diagnostic ports and programmed their ECU's so they could be read with any scan tool, just like cars and light trucks of today can be read.
They are all basically using similar emissions hardware anyway but none of their ECU's are compatible with each other.
   / 1st Regen Mode and then to the Shop #4
Sort of similar to JD's 'right to repair fiasco. You cannot access a JD unit with a non JD scan tool and to make it even worse, JD won't sell the average Joe farmer a compatible scan tool at any price. Even worse are the newer JD farm tractors, combines and spray rigs. Note I don't own any green equipment and won't but the newer units, the units actually communicate with the selling dealer via the Greenstar Satellite communications sytem and the unit tells the dealer when it's time to service it and get this.. The unit owner if he changes the oil, has to use JD filters because the filters all have microprocessors inside that tell the dealer stuff like filter restriction and if the filter has failed so the filters have to be replaced with JD filters only or the unit goes into limp mode....and limp mode don't work when farming, if you can even get a unit out of the barn. My buddy down the road runs JD exclusively so I get first hand experience with them. His units communicate with the dealer and then the tech shows up at his barn, performs the required services and charges him for that and he (tech) don't call ahead, he just shows up. Heck of a way to run a business.
I've had no 'woes' with the emissions system.
   / 1st Regen Mode and then to the Shop #6
Consider yourself blessed but when you do, you'll be at the dealer's mercy and shop rate 100%.
Emissions related components under the EPA mandated guidelines are 'supposed to be guaranteed for 5 years, no exceptions, but it appears to me that a lot of dealers attempt to skirt around that and 'blame' emissions components failures on non emission component parts so they can charge the customer to fix them and what happens after the 5 year guarantee is up and they fail?
I guess you could trade in every 5 years for a new unit and take the depreciation hit and be happy. Don't work that way for me. For me, a tractor purchase is a large investment and I expect the unit to be viable for way more than 5 years. and...
If you peruse the used tractor market like on Tractor House for instance, almost every for sale ad states 'Tractor is a pre emissions unit' Why do they list them as such? Simple answer, because buyers don't want an emissions compliant unit plus non emissions tractors really retian their vaule.
I know that well. Both mine are pre emissions and I've been told (by my dealer) that they are worth if I sold them, at least as much as I paid for them new. Not that I would, simply because I don't ewant the grief, emissins compliant units have.
Here's the 411:
Shop found the starter was bad. Also replaced a recall on the HST pedal rod. Here is a breakdown of starter issues on this model according to chatgpt:
You said:​
how can a tractors starter already be bad after only 25 hours of use?
ChatGPT said:​
A tractor starter failing after only 25 hours of use is definitely unusual, but it can happen—here are some of the most likely reasons:
🔧 1. Manufacturing Defect
Even brand-new parts can be bad from the factory:
  • Poor soldering or internal connection.
  • Weak brushes or bad armature.
  • Cheap materials (especially in off-brand or budget models).
⚡ 2. Electrical System Issues
If the starter is being overworked or underfed:
  • Weak battery or low voltage can cause excessive strain.
  • Bad ground or corroded cables lead to poor current delivery.
  • A faulty solenoid or starter relay can cause improper function or arcing.
🔁 3. Frequent Short Starts
If the tractor is started often for short runs, or cranked excessively (e.g., hard starting due to fuel or ignition problems), that will wear a starter fast—especially if it’s a gear-reduction type with small internals.
🌡️ 4. Heat or Moisture Damage
  • Starters mounted near the exhaust can overheat.
  • Exposure to water/mud (common in compact or utility tractors) can corrode internal parts if not sealed well.
🧰 5. Misdiagnosis
The starter might not even be the problem. Symptoms like a click or no start could actually come from:
  • Bad battery
  • Poor connections
  • Faulty ignition switch
  • Bad safety switches (seat, PTO, brake, etc.)
✅ What to Do​
  1. Check voltage at the starter during crank.
  2. Inspect cables, terminals, and grounds.
  3. Verify battery condition (load test or multimeter under load).
  4. If confirmed bad, check warranty—most new tractors should cover this kind of failure.
If you let me know your tractor make/model, I can check for common starter complaints or technical bulletins.
You said:​
No it was the starter, and it has been replaced. It is an LS MT242 HE
ChatGPT said:​
Thanks — that helps clarify it.
If the starter on your LS MT242HE failed after only 25 hours and was confirmed bad and replaced, here's a breakdown of what most likely happened, based on known factors about that model:
🔍 Common Explanations for Early Starter Failure on an LS MT242HE:​
1. Defective OEM Part
  • LS tractors (including the MT2 series) source starters from third-party suppliers, often Doosan or a Korean/Japanese brand.
  • Occasionally, a bad batch of starters slips through quality control — internal short, weak solenoid, bad brush alignment, etc.
  • Other LS owners have reported early failures on electrical components (including starters and sensors), though it's not widespread.
2. Solenoid Burnout or Engagement Issues
  • These tractors use an inline solenoid mounted directly on the starter. If the solenoid sticks, it can cause:
    • Over-cranking
    • Arcing
    • Premature motor burnout
3. Starter Engagement Misalignment
  • If the flywheel ring gear and starter pinion aren’t perfectly aligned (rare, but possible from factory assembly), it can wear out the pinion or damage the motor trying to engage.
4. Vibration or Mounting Problem
  • LS tractors do vibrate more than higher-end compacts (like Kubota or Deere). If the starter wasn’t firmly torqued or properly shimmed, it could shift slightly, causing internal strain or contact issues.
⚠️ Should You Be Worried?​
Not necessarily. This is likely a rare one-off failure. If:
  • The replacement starter is working fine
  • No unusual electrical symptoms persist (hard starts, slow crank, click/no start)
...then you're probably in the clear.
   / 1st Regen Mode and then to the Shop #8
Who the heck is chatgpt and what makes them an expert on this subject? Looks like an AI generated story. I think it's funny that they said LS tractors vibrate more than higher end compacts like Kubota or Deere. Who decided that? Deere uses Yanmar engines in their compacts also, like your MT242. I used to work at a Kubota dealership and they had a ton of engine problems. Kubota wouldn't let us fix them and sent a new engine in a crate when we had a failure. We had a shed full of old engines that had to be scrapped. They made us show proof that we had destroyed them so they couldn't be fixed and re-used before they sent the new engine.
I am also curious where the information came from that dealers are charging customers for emissions repairs that are supposed to be covered by the 5 year emissions warranty by blaming emission component failures on non-emission related parts.
Who said it's an expert?
It's AI. This searches the web for information provided by real events, complaints, other data. Sometimes it is spot on, sometimes not.
Ya think?
Yes, yes, of course, contrary to all the people I've talked to with the LS, they're really just a pile of junk, and soon enough I'll have a pile of engines in the barn. They probably all have piles of engines too, but never told me.
Maybe you should ask chatgpt. ;)😁
   / 1st Regen Mode and then to the Shop #10
It's AI.. It's only available sources are whats published online in articles and forums, so take it's 'findings' with a grain of salt.
2018 CATERPILLAR 308E2 CR EXCAVATOR (A50458)
2018 CATERPILLAR...
2014 VOLVO VHD (A50854)
2014 VOLVO VHD...
2005 JOHN DEERE 310G BACKHOE (A50458)
2005 JOHN DEERE...
2020 FREIGHTLINER 26FT BOX TRUCK (A51219)
2020 FREIGHTLINER...
2022 FREIGHTLINER CASCADIA SLEEPER (A51222)
2022 FREIGHTLINER...
UNUSED INDUSTRIAS AMERICA F08 - 8' LAND LEVELER (A50459)
UNUSED INDUSTRIAS...
