1st oil change
   / 1st oil change #1
Pops Posse
I just bought a Cud Cadet 1046vt. I see it recommends an oil change after 5 hours. It does not mention the filter. Would I be better off changing the filter also, or is this overkill at 5 hours.
Thank you.
Mike
   / 1st oil change #2
change 'em both. That filter catches all that left-over mfg grit from inside the engine crankcase and also whatever is shaved loose while the engine breaks in those first few running hours...
   / 1st oil change #3
yes for sure change both
3235
1872
782
   / 1st oil change #4
I have a cub cadet 1042 ltx . basically same tractor but with a 19 hp kohler engine and a 42 inch mowing deck. I would double check your manual as it recomends changing the oil and filter every 50 hours not 5.
   / 1st oil change #5
best read that manual again - you'll find that it calls for a new engine's oil to be changed at much lower hours than 50.
after that, the oil change intervals will be greater.
   / 1st oil change #6
I read it again and it says to change the oil and filter every 50 hours.
Riding Tractors, LTX 1042 Riding Tractor Page 19
and for the ltx 1046 vt:
http://www.cubcadet.com/wcsstore/Cu...owners manuals/residential/2010_LTX1046VT.pdf Page 19
B.T.W. If you compare the hours to a vehicle;50 hours times an average speed of 60 MPH
equals 3,000 miles, which is the recommended oil change for most vehicles. Changing the oil every 5 hours is almost like changing the oil in your vehicle every 300 miles
And also I have a 2004 Kubota that stated to change the engine and transmission fluids and filters after the first 50 hours
and then every 100 hours after that. And after 6 years it is running great with no oil usage.
   / 1st oil change #7
I second that. I've read a lot of the Cub operator manuals and they vary from 5-24 hours for the first oil change and from 50-100 hours for regular changes depending on the engine. If his manual says 5 hours then I'd do it and make sure you note it and all service with date/hours in the back of the manual in case you ever need warranty service. I even save the receipts for the oil and filters just to back up what I wrote.
   / 1st oil change #8
change the oil and filter with each oil change. the 50 hr point is most likely the regular interval with 5 being the break-in interval. i know with cars after a cam swap, you change the oil after 20 minutes of run time at an elevated rpm. even if the owners manual doesnt say to, i would definately do something around 5 hours to get rid of any sludge from break in.
   / 1st oil change
To clear things up a bit, it's the Briggs and Stratton manual that came with the tractor that says to make the initial oil change at 5 hours.
   / 1st oil change #10
i would change the filter too. its on a little bit of money in the grand scheme of the life of the mower.
2014 Chevrolet Tahoe SUV (A50324)
2014 Chevrolet...
2018 Allmand Light Tower (RUNS AND WORKS) (A50774)
2018 Allmand Light...
3400 (A47384)
3400 (A47384)
Land Honor Quick Attach Bale Spear (A50515)
Land Honor Quick...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
John Deere 918 Flex Head (A50774)
John Deere 918...
