1995 B7100 weight?
/ 1995 B7100 weight? #1
MoreMowing
Eastern Massacusetts
1995 Kubota B7100
I just purchased a used 1995 B7100 and I need to rent a trailer to pick it up. Looking on Tractor Data.com, it lists this tractor at 1,080 lbs. Is this correct?
It comes with a 60" belly mower which from what I am told adds another 370lbs.
Does this sound accurate??
Thanks for you help!
/ 1995 B7100 weight? #2
That sounds about right. My B6100 (very close hardware but less HP) is about 1500 with a loader and no mower according to my manual. In NH it seems close to impossible to rent a trailer for tractor moving. I've used a tow service with a flatbed in the past. It was cheap and painless but the distance wasn't very far. Good luck.
/ 1995 B7100 weight? #3
Your going to like that work mule alot. :)
Post pics when you can.
Thanks guys. This will be about a 2hr drive for me but I have a flatbed trailer ready to go that is rated for 3,000lbs. Should be no problem.
I'll send some pics as soon as i get her here!
/ 1995 B7100 weight? #5
That's about the right weight. I've moved mine on a 2000# capacity equipment trailer (mesh over angle iron construction) and on a small car trailer. Car trailer was definitely overkill.
This trailer is a wood plank tilting flatbed equipment trailer. Designed for ease of off and on. it is 76" between the wheels and 10' long.
I think I will be OK......
Just need to be sure she's strapped down well! :)
