1980's 4600 ford tractor
   / 1980's 4600 ford tractor #1
Buster Myer
Jackson,al
2007 new holland tt 45 a
My fathernlaw mistakenly put 10 gallons of gasoline in his tractor. What should I do?
Gasoline in a diesel tractor what should I do?
   / 1980's 4600 ford tractor #3
Drain it out! Open the line downstream of the filter and run it into a container. Put in a fresh filter, fill the tank with diesel and bleed the filter and the fuel system clear to the injectors. It should be OK. If you didn't try to start it, the gas wouldn't have got beyond the filter. If you did, the engine will start when it gets diesel in the cylinders.
Thanks so much Jerry! Gotter done and running good now. Got to figure out how to keep him from doing it again. Thanks again Jerry.
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
JOHN DEERE Z920M LOT NUMBER 238 (A53084)
JOHN DEERE Z920M...
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2007 International 7500 sba Flatbed 6x6 Truck (A52384)
2007 International...
2018 FORD TRANSIT T150 CARGO VAN (A52577)
2018 FORD TRANSIT...
FRONTIER MG20F LOT NUMBER 82 (A53084)
FRONTIER MG20F LOT...
