1969 110 with patio deck... WIW?
   / 1969 110 with patio deck... WIW? #1
Brockwaykid
Granville NY
John Deere 317 (KT17 SII)
I just came across a 1969 JD 110 hyd lift with a patio deck near me on craigslist. I was wondering what the 2 of them would be worth. I think the price he has on them is pretty reasonable, just curious to know. Obviously the dust cover and side panel are missing, and the seat is cobbed up.
John Deere 110 W/ hydraulic lift Garden tractor/ lawn mower
   / 1969 110 with patio deck... WIW? #2
It wouldn't be worth anything to me but it you want to invest $500 or so in parts to get it running,$150-200 might be OK. The deck belt will be about $70, bearing in the shafts likely shot also. I don't know if you can repair them or have to replace the shaft. ON my 332 JD the bearings were replaceable and IIRC $14 got both top and bottom bearing for one shaft. Carb might be an expensive item to clean and repair @ least $100 for that. I have no idea how much the side sheet metal might cost or even if you could still buy it. If engine isn't running you wont be able to see if the HST transmission is even working so that is a big gamble. With a bad transmission, it is worthless for anything other than scrap.
   / 1969 110 with patio deck... WIW? #3
I think 250 or less, less would be better. It sounds to have a few issues that will end up needing more coin tossed at it. 110 square fenders are gear drives, no hydro trans to worry about however well worn units tend to pop out of gear and rear hub/axle splines can be worn, again you'll be tossing more coin at it.
Parker 2600 Gravity Wagon (A50775)
Parker 2600...
UNUSED LANDHONOR FW-13-15000G HYD WINCH (A54757)
UNUSED LANDHONOR...
(2) 5' TRAILER RAMPS (A54756)
(2) 5' TRAILER...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
