1965 ford 5000 hydraulic pump?
/ 1965 ford 5000 hydraulic pump? #1
jhp123
VA
1965 ford 5000 2000 new holland 1920 4wd, 1974 ford 5000, 1975 ford 9600, 1988 case Ih 885
I have a 1965 Ford 5000. The 3 point stopped working suddenly will not lift at all, even without a load. PTO still turns. Am I looking at a new hydraulic pump? Are there some more common smaller part failures that may cause this? If so, which one would you think is the most likely? We don't have a lot of experience diagnosing, don't want to just throw parts at it either hoping to find it. Too expensive and time consuming :)
/ 1965 ford 5000 hydraulic pump? #2
The hydraulic pump mounted on the back of the engine is pretty easy to rebuild. Your PTO is independent with its own pump, that's why it's still working.
I'd check remote pressure first before I tore into it. If the pressure is good, it could be a stuck relief/unload valves, blown o-rings and seals. If no pressure, rebuild pump, change filters/fluid and complete overhaul of sump/lift housing cover. The parts are cheap and you'll be in there anyway.
