1952 8N Brake problems
/ 1952 8N Brake problems #1
depdir802
Does any one know how to fix the brakes from leaking fluid from the rear end onto the pads I have replaced the seals pads the gaskets and still have the same problem. I might have them for a lil bit but then the get oil soaked and im without brakes. If I can get these fixed i plan on buying a small bush hog to mow with
/ 1952 8N Brake problems #2
Take the axle out, replace the outer and inner seals, the gasket and that should fix the problem. There is no where else that the oil could be coming from.
/ 1952 8N Brake problems #3
Grooves wore into shafts where the seal lip rides ? Maybe you can use speedi sleeves over the grooves if this is the case.
Ben
/ 1952 8N Brake problems #4
Ditto on the other two posts. Most people are used to the older N's with only outter axle seals and forget that the later N's have 2 axle seals. Also. if the axle is groved.. try to sleave it.. or at least braze it up then turn it down smooth. Some even use jbweld with great success.
Also.. really sound slike you are running with way too much oil in the rear end. It is only made to use 5 gallons anyway, and most people overfill. The 'accepted' method is to remove a lower bolt on the round inspection cover, and only fill till oil comes up to that level. Probably about 4.5g's. This keeps oil from pooling at the seals in the axle, and the tranny input shaft seal.
Also.. if you are using the new style UTF / 134d oil.. you may want to consider going to a 90wt gl-1 or gl-3 oil. 90wt gl-1 is available at many wallmarts, and at napa as part # 65-205.. Also.. TSC sells a 'ford tranny fluid for tractors 39-52'.. this is widely believed to be very close to the oem 90wt fluid, and to be mildly ep.. like the new 8n manula specified.. perhaps like a gl-3.
The thicker oil is less prone to escape weak seals, and also may help the lift be a tad stronger and knock less. In cold weather it will need a few minutes to warm up.. and I reccomend you depress the clutch when starting to prevent the starter having to drag over the tranny in that thick oil.
Soundguy
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2024 DODGE TRUCK BED (A65643)
2024 DODGE TRUCK...
60in. Loader Forks and Frame Attachment (A61572)
60in. Loader Forks...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2006 TerraGator 8104 (A63688)
2006 TerraGator...
2001 John Deere 6210 (A60462)
2001 John Deere...
