1920 restart
   / 1920 restart #11
My bet is fuel solenoid valve is not reopening. Next time it won't start, take a 'jump box', or similar, and connect 12V to the fuel solenoid post, ground to chassis anywhere. You should hear a 'click' when the valve opens. Then try starting. If it starts, I would check for a wiring problem before I replace the solenoid valve. My wiring problem was behind the dash where rodents had chewed much of my wiring harness.
Here are some pix of the fuel solenoid that might help: How to remove the fuel shutoff sol... - Yesterday's Tractors
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A55315)
PENDING SELLER...
2014 JCB 930 (A53317)
48'' ALUMINUM MAN BASKET (A56857)
48'' ALUMINUM MAN...
New Holland TS6.120 Power Shuttle 4WD 120HP Agricultural Tractor (A56857)
New Holland...
24ft T/A Flatbed Equipment Trailer (A55788)
24ft T/A Flatbed...
2023 Kubota SVL97-2 Compact Track Loader (A55315)
2023 Kubota...
