1920 Rear Bolt Pattern Measurements
   / 1920 Rear Bolt Pattern Measurements #1
4EverWest
Ford 1920
New 1920 owner here with rusted rims in need of a new rear set. I found a set of wheels off a combine with a 6" center hole and an 8 lug by 8" bolt pattern. Anyone know what the exact specs of the 1920's rear bolt patter might be? Also, is there any concern as to offset? Thanks in advance!
   / 1920 Rear Bolt Pattern Measurements #2
1920 bolt pattern is still metric. TC models went to standard sizes. I can get you measurements if you like.
TractorTech, that would be great if you were able to take some measurements for me. I'm 1300 miles from my tractor, otherwise, I'd do it myself. Many thanks!
   / 1920 Rear Bolt Pattern Measurements #4
4everwest, I have 2 complete wheels with dishpans, 11x24. If you are interested in buying them, I would sell for $300 each plus freight.
Measurements are:
Hole center: 150 mm (5 7/8")
Bolt circle: 200 mm (7 7/8")
Bolt size: 16mm (5/8")
2015 Ford Escape SUV (A55853)
2015 Ford Escape...
2006 Utility Trailer MFD. T/A 32FT Dry Van Trailer (A56858)
2006 Utility...
23013 (A55787)
23013 (A55787)
2022 RAM 2500 HEAVY DUTY (A58214)
2022 RAM 2500...
MAYTAG ATLANTIS WASHER & DRYER (A54757)
MAYTAG ATLANTIS...
LOT LOCATIONS (A57880)
