1920 4wd actuator broke (inside)- Anyone know what it looks like inside?
   / 1920 4wd actuator broke (inside)- Anyone know what it looks like inside? #1
Jlw4141
Ford 1920
The 4wd lever/actuator rod on my 1920 has zero resistance and doesn't engage the front axle. The linkage is intact, so whatever is broke is inside the trans/diff. Anyone know a likely culprit in there? Before i dig into anything i thought id see if there was a common failure point so i could see if the part is even available.. Thanks for any advice
   / 1920 4wd actuator broke (inside)- Anyone know what it looks like inside? #2
There is a couple of salvage yards I called for my 1920 Ford. I needed a hood and they had a lot of 4x4 ford parts. I used google and searched parts for 1920 Ford tractor. Hopefully they will have the parts you need. Also have you gotten a factory repair manual to see the parts that might be damaged?
I did get it sorted out, thanks. its simple little lever that slides the gear on a splined shaft either into or out of position to mesh with the driveshaft gear. you can remove the mechanism fairly easily. its held to the trans housing with 4 13mm bolts, then you basically turn it a little and it pulls out. I do have the factory manual, it is very helpful but doesnt show much detail for that part. Thanks
19010 (A55851)
19010 (A55851)
2005 MERCURY Grand Marquis (A56859)
2005 MERCURY Grand...
2019 Toyota Rav4 LE Hybrid AWD SUV (A55853)
2019 Toyota Rav4...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
Eagle Weathervane (A55853)
Eagle Weathervane...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
