187d yanmar
   / 187d yanmar #1
cinder
yanmar 187d
I have a 187d yanmar and when i have the range shift lever in high and i put in first gear or reverse it takes right off, but if i put it in second or third gear or shift while moveing it slowly goes into gear . Not all at once but like you would be letting out the clutch but of course the clutch is already out is this normal? Only does this with when you have the range lever in high.
   / 187d yanmar #2
Sounds like your clutch is slipping. Higher gears just aggravate the situation. Is it adjusted properly?
2006 STERLING L7500 DUMP TRUCK (A51406)
2006 STERLING...
2018 Chevrolet Equinox AWD SUV (A53424)
2018 Chevrolet...
23311 (A51694)
23311 (A51694)
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
2012 JOHN DEERE 10-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
2006 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2006 FORD F750 XL...
